Old 05-29-2008, 12:40 PM
RedBarchetta RedBarchetta is offline
Banned
Dex, if you're careful and can handle a razor blade, masking tape and have some patience, you can make your own and do it yourself. I did my SPF by buying black sheets of 1/8" foam rubber from a hobby/crafts store. Then cut to fit for each wheel well (given how they curve, you might need 6-8 different pieces that you put together like an upside down jigsaw puzzle). Clean the inner wheelwells very thoroughly with wax & grease remover, then start on one end and use 3M spray adhesive (contact cement in a can). Trim to within 1/4" of the wheel well lip. And once dry, mask everything off (including the outer painted lip) and spray on 2-3 coats of any rubberized bed liner (I used some from Blue Magic and it worked great).
I will admit that it's a bit of a job and you can kill a whole weekend doing it right. But it works!
Good luck,
-Dean
