  #39 (permalink)
Old 05-29-2008, 02:21 PM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Originally Posted by Jamo View Post
It will screw up valve stems and plays hell with pressure senders in modern cars.
With the low pressures we run in the Billboards, I can't see it as much of a problem when they have to break the bead...I don't leave it in there long enough (just to get home).
Assolutely a no-no with run-flats (course, you don't need it to limp home), as Goodyear and Chevy make plain in their literature.
What pressure to you run in your tires. I did a search and what I found was 26 in the fronts and 24 in the rears. Is that in the ballpark?
