Originally Posted by Jac Mac
You have a one piece eccentric--you have been supplied with a cam equipped with a short dowel that is intended for a two piece eccentric ( tang type ).
Wonderful...So how come this lasted as long as it did? Was there just enough of the cam dowel showing through the gear to grab the eccentric before it receeded back into the camshaft?
Remove that dowel--usually a large set of side cutter pliers will suffice, using the gear spigot of the cam for leverage.).
Not sure I follow you on using the gear spigot for leverage.
Buy & fit the correct (longer) dowel.).
Where can I source this? Machine shops? Hardware store?
The gear set for a two piece eccentric usually has a raised lip in center that allows the outer ring to turn freely once fitted.
So what you're saying is that I
can't just install a two piece like what should have been there to begin with?
I'm going to try to post a pic tonight.
Thanks,
-Dean
