I didn't break anything. Just a bunch of stuff I've wanted to do. So I figured if I put it up on jack stands and take all the wheels and brake rotors off, I will have to get all of it done.
I just finished having my guys modify the rear coil over mounts. Mine weren't bent, but they were at an 80 deg angle instead of 90 deg to the frame. I also pulled all my rotors and had them turned since one or two were slightly warped. Next I have to pull my clutch pedal and re drill the center hole for a bigger pin. Mine was a bit worn out. And, change rear end
oil, throttle springs, front wheels bearings and seals since its apart, rear axle nuts since I have the old crap ones, and about four or five other little things.
Scott
