It seems that quicktime housings are the new king in this market. I have a lakewood, and I had to use offset pins to dial it in. It was pretty far off. It weighs a pissload, and there is that big old flange on the bottom. I too have heard people say that the Quicktime's are more likely to be within tolerance as far as dialing in is concerned, they weigh less, and they have that modular construction that means that you could change trannies without having to get a whole new bellhousing.
I would go with the quicktime if I were doing it all over again, but that lakewood being so thick and heavy does make your balls feel safe.
If I can see you, I'm too close
