Old 05-31-2008, 01:36 PM
blykins blykins is offline
So you're just going to retorque and see if that fixes the problem? I guess it's worth a shot.
It's not a big ordeal, just grab a torque wrench and go through over each head bolt. If you used ARP bolts/studs, I'd set your torque wrench at about 100lb-ft and follow the torque sequence.
Same for the intake manifold, set at required lb-ft spec, and go through the sequence.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
