Old 05-31-2008, 02:32 PM
MrMagoo's Avatar
MrMagoo MrMagoo is offline
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
Default Clutch Adjustments
I just installed a new motor and a G-Force T5, with a Ram HD clutch, and a CNC slave cylinder (pull type). It all works well, with one major difference from my old setup: I have to step way down on the clutch to shift, whereas I used to be able to go about halfway down.
The clutch as it is right now is smooth on take off, sort of just right. I could live with the way it is, and just remind myself to push all the way down on the clutch.
My question: Would it help if I just tighten the nut on the clutch fork more? I don't want to start slipping, or make take-offs less smooth.
If I can see you, I'm too close
