Old 06-01-2008, 05:42 AM
undy's Avatar
undy undy is offline
When you retorque, loosen the bolt apprx 90 to 120 rotational degrees then retorque to spec. That way you'll get an accurate retorque. As Blykins hinted, IMO you have about a 5% probability (very slight) that this will fix your coolant leak probs. Since these are original iron heads they could have been subjected to many machine shop/owner/jack leg atrocities over the years. Someone could have minutely busted into a water port during reckless porting or you could have a crack that's causing the leak. I would have the head(s) pressure tested before they went back on. Pay particular attention to the cylinder sidewalls in the lifter valley area of the block. That's a weak spot for OEM FEs (freeze busting). A dye penetrant check of that area wouldn't hurt either. This is all assuming you don't find anything with you head gasket inspection.
Rick, you need to stay up a lill' later in the evening (old fart syndrone) so you can sleep a little later in th AM..
Dave
Too many toys?? never!
