Old 06-02-2008, 09:08 PM
Double Venom's Avatar
Double Venom Double Venom is offline
WD,
You've lost me?? Gap? Referring to the floor pan? If that is the case, the floor pan is not welded all the way around. I just assumed CRII did that for drainage. Lets face it when a Cobra is washed it definatloey gets wet inside, especially the jute padding. Water needs some place to go. More likely to get wet from the top and drain out, vs. driving in the rain and picking up road water-even so it has to then go somewhere.
Totally sealed floor pans, whether fiberglass or steel have a tendancy to mold or even rot without some type of drainage.
Maybe I am totally off your comment--if so sorry!
DV
