Thread: Spring Rate?
Old 06-03-2008, 12:39 PM
Silverback51's Avatar
Silverback51 Silverback51 is offline
Remember when setting your ride height, that the recommended 27 inches to the wheel well opening is with the stock tires.
Change the tires to a different diameter tire and the ride height will also change.
I just went with the Goodyear Billboards and they are .45 and .60 (if I remember right) less in radius front and rear respectively. So that means if you tried to raise the height back to 27 inches you would have a larger gap between the tire and wheel well opening.
