  #23 (permalink)
Old 06-03-2008, 02:55 PM
wtm442's Avatar
wtm442 wtm442 is offline
Beam Me Up Scottie
Originally Posted by MrMagoo View Post
The pressure seems to be staying steady at 6.5. The engine is just up to normal operating temperature when it honks out. Although I think, in general, my fuel temperature issues need to be addressed, I am now leaning towards jetting as the main problem. Carb tuned for max power, I have a restricted exhaust, hence too much jet for the air I can pump.
Overly rich jetting is NOT going to make the engine quit in 5 minutes. Put in the carb spacer before doing any carb changes.
Then adjust your float levels. Check float levels again after a 5 minute drive where you open the secondaries a couple of times. I know that will be a tough job.
Now check the condition of the plugs. It is probably time to change them. Now set the idle screws and take it for a ride. If it still smells rich, then change the jets.
When I first bought my Cobra (used), it smelled very rich. I adjusted the idle screws and the smell from the exhaust was eliminated. Then I had one dyno pull, just to see what the mixture was like. It was LEAN. I had to go up in jet sizes - 3 steps on both the primaries and secondaries. What a difference!
The 7 PSI at idle is OK. If you bought a Holley Fuel Pressure regulator, the factory setting is 7 PSI. Of course, you should also have at least 4 PSI when running flat out ... thru the 1/4 mile traps, for example.
Warren
