I second to stay with the smaller cam. I don;t think you'd gain much with the bigger cam as your engine is limitied to just north of 6000 rpm's. Ask KC for some dyno sheets comparing the two cams, and make a decision. The smaller cam will be alot better at lower rpms especially since you're likely using a standard tranny.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
