Thread: Wheel clearance
Old 06-06-2008, 08:32 PM
Tenrocca's Avatar
Tenrocca Tenrocca is offline
Sill hight seems fine at 180cm without motor.
Perplexing!
Man you have that baby jacked up...wicked!
Seems to be a common problem with a few kits that the bodies arent centered right on the chassis - Took ages to get mine straight - bloody annoying.
Depending on the wheels you may be able to get the contact hub mating face machined a little, and maybe ge teh hub nmachined a little too to bring it in when you need too. As the suspension works up as youve seen, it will pull the wheel in - I think if you dont have clearance issue with the gaurds, and can possibly borrow a set of rear wheels for rego - having the wheels as far out as possible looks good IMHO. I tries to push mine to the limit.
You cant tell me these rears a fully inside the gaurds at ride heigt - I think it looks tough:
