different makes.
Hi Side show you would really need to measure up a car your self and work out a standard routing layout .
and some cobras are harder than others to get the wiring to where it needs to be. But if there is one thing about all the factory looms i have installed is that they never put enough plugs on them ie a rear loom, front loom and a cabin loom,
It just makes it so much easier if you can fit them up indavidually. Then plug them to gether its more work but the end user will be much happier. 2 other things that might help is a dedicated fusable link and relay 40 amp for the thermofans . and plenty of relays . the first loomi got from rmc had one relay in it for the horn. what a joke that was.
Try and talk to some car builders as to what they think is needed in a loom.
hope this helps.
Oz.
