  #31 (permalink)
Old 06-08-2008, 01:01 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Thanks for the heads up info on float height specific to Quick Fuel. The setting does differ from Holley and the other "patterned after" carbs. A 1/2 inch or so increased float level is significant. The Quick Fuel carb is not a standard holley copy.
The issues with the (see through - solid plastic) bowl plugs has been leaking if they break/crack the outer lip of the plug. The plug has a surface that seals against the bowl as it is tightened in place. The brass plugs are tough but the solid clear plastic plugs can be break and leak. I do not know if the plugs were torqued too much or just a defect but the solid plastic ones seem pretty lame to my standards anyway. The metal body plugs with a clear window in them are much tougher and work great.
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
