Old 06-08-2008, 05:52 PM
ENTDOC's Avatar
ENTDOC ENTDOC is offline
it would seem to me that you could not balance the carbs if you had a vacuum leak that affected only 2 of the carbs. Can they be balanced? If you hold the balencer on each of the carbs and run it up to 2500 or so , if 2 are out of balance you should be able to tell, at least you will know which carbs are out of synch
