Wetdog, an SVO agent is looking now or he may even have them????
The spillage well is only needed for the lemans cap.
Finish line wiper system is a perfect match, they will supply you a small thin (cheap?) clamp to mount it with which YOU will probably change although I do find them to work well.
They will not supply you the "tubes" to run the cable through. I find that 3/8's aluminum fuel line works great. It is very easy to bend to match the cowl, allowing the cable to pass through with out making all kinds of noises and of course it will be the easiest SINGLE flare you have ever done. (The tubes need to be flared coming out of the motor, into the right side of the wiper transmission. Then flared again as it exits the bracket for the wiper transmission going to the drivers wiper transmission. One flare on each side here please as all the flares will keep the tubes in place when thre wipers are on.
Clear as mud-Hey?
DV
