Old 06-11-2008, 06:27 AM
Flyin_Freddie's Avatar
Flyin_Freddie Flyin_Freddie is offline
Cobra Make, Engine: Superformance #770, Stroked 351W (393 cubes) w/ Tremec TKO-600, 3.27 Torsen locker, 'Hi-Tech' Blue w/ White Stripes, Wilwoods, Bilstein coil overs...and a big ear-to-ear grin!
John...I mounted my T-handle to activate the fire suppression system under the dash. My SPF dealer, Olthoff Racing, offered an electric accessory outlet under the dash, mounted on a L-bracket...really a cigarette lighter socket, if you will. They turned the L-bracket around backwards, so the bottom part of the "L" was on top, and facing towards the rear of the car - got the picture...? Then, they drilled two small holes in the bottom part of the facia panel under the dash and bolted it to the underside of the facia panel, with the bottom part of the "L" actually hanging on top of the under side of the facia panel...I know, I know...confusing explanation... Think of it this way...the "L" is upside down, facing the rear of the car, and hanging on the inside of the facia panel. (Hell...that may be worse...!)
Anyway, when I installed my fire supression system, I brought the pull handle cable down the transmission tunnel and inside the frame rails...then a big gentle curve up to the upper right-hand side of the transmission hump. I cut a piece out of an aluminum trailer tie-down bracket to duplicate the L-bracket they had used for the accessory socket....shaped it up and smoothed all the curves out with a file, and then, simply drilled the holes and mounted the new bracket right next to the accessory socket. Looks like it came out of the factory...professional looking, non-obtrusive...easy, too...and, more importantly, easily accessible from the driver's seat even with a harness on.
I'll snap some photos today and post them here, if you'd like.
Flyin_Freddie
"An opinion on everything...an expert at nothin'!"
WARNING: The opinions expressed herein do not necessarily represent those of the management, editors, or owners. We welcome differing opinions, and recognize our responsibility to offer differing views. May cause drowsiness, restlessness, or irritability. Do not operate heavy machinery while using this product. Void in Alaska, Hawaii, and Puerto Rico, or where prohibited, licensed, or regulated by law. We reserve the right to limit quantities. Offer good while supplies last. No substitutions allowed. Please observe posted speed limits. Professional driver on closed course. Do not try this at home. Please wear your seatbelt at all times. Close cover before striking. Use at own risk. Please dispose of properly. Drink responsibly. Prolonged exposure to vapors has been shown to cause cancer in laboratory animals. Do not use this product of you are pregnant, or plan on becoming pregnant. Intentional misuse by deliberately concentrating and inhaling fumes can be dangerous. Always wear safety glasses. In case of eye contact, flush with water and seek immediate medical attention. For occasional use only as directed. Avoid prolonged skin contact. Discontinue use if rash develops. If symptoms persist for more than three days, seek professional medical attention. Hearing protection required beyond this point. Danger: Hot surfaces. Use as directed. Proceed at own risk. Caution: Filling may be hot. Please don't litter. Actual results may vary. It is a violation of Federal Law to use this product in a manner other than as intended. Do not use this product if you have an enlarged prostate, or have difficulty urinating.
