Old 06-13-2008, 04:06 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Terry,
You have one of the older but definatley better tops. You should have a plastic bag with "T" bolts in it. Small black allan head screws (8x32's?) and the same amount of brass T's. The brass T's do slide into the grove on the top of the windshield then the screws are installed and should go tight against the windshield frame with about an 1/8" sticking up. This is what your slots of the top will slide into. You may have to grind off a very small amount of the sides of the "T" to get them to fit. Seems that some where just a little to wide to slide in place.
DV
DAN:That's a completely different top than what Terry has-looks like a newer style?
