Old 06-13-2008, 06:22 PM
McDoo McDoo is offline
Cobra Make, Engine: Former owner of Sp931
The thermo switch acts as an an open until the temperature hits the desired result and then it acts as a short to ground tripping the relays. Sounds like your the radiator is isolated from chassis ground. Pull the wire off the thermo switch and connect directly to ground and if the fans come on that's your problem......
McDoo
