Originally Posted by dblvenom
I have an SPF MKIII about a year old. I am experiencing a problem with the my radiator cooling fans.Specifically, the fans are not automatically engaging. I thought the problem was with the thermo switch that taps into the radiator so I replaced it. Unfortunately, it did not solve the problem. The fans work if I use my manual dash switch. Has anyone had a similar experience and if so can they share their insight on a fix?
Thanks
How did you test the fans? Mine come on once the temp guage reaches ~95.
When they are on ( either automatically or manually) is the ammeter almost to the minus extreme? Didnt think the fans had that much of a current draw and wanted to check.
