Hi, Jac.
Where do you find those jetting info's? My John Passini book isn't as fine- tuned as your data.
Sounds like the 41 mm off- the- shelf mains are the way to go.
No; it will not run @ 8000 continously, I'd say. But Eagle sayz 8000 is fine with the "2000" rod bolts.
I was quite sure the long rods opt'ed for longer dwell period and less rod/ cylinder wall angle which again means it will take more beating.
So, what are you refering to whan you say it can't stand the 8000 rpm beatin'? Rotating mass?
Regards
Rune
