Old 06-14-2008, 05:46 AM
OZVENOM's Avatar
OZVENOM OZVENOM is offline
Cobra Make, Engine: Now built a race cobra.
Default mount.
Hi when i mounted the throttle in a customers drb cobra i cut down the plastic bracket it came on and made a metal mount to go on the plastic bracket then mounted it to the fire wall .
I had to re-enforce the bracket as it flexed a little.
make sure its solidly mounted.
Also FYI the throttle will not open until the engine is started.
It will reset its self to a starting position when you turn on the ignition you can hear it.
The only negative from the customer is it feels a little vague some times when you gas it up. other than that it works fine.
Regards oz.
Left Foot Up Right Foot Down.
http://www.venomcobras.com
