Originally Posted by Blas
Steve-o.
As mentioned below, just connect the two wires on the radiator fan switch (lower left hand corner) that should start the fans spinning. If not, keep them connected and add a new ground wire to them. Still not running? then it's a power issue....The fans do draw a lot of power but should not peg the AMP meter all the time. Contact me off line for further things to look at. SPF car numbers would help too.
Blas
Dblvenom, are you testing your fans with this technique or letting the temp rise and seeing if they turn on?
