If you are worried about it being balanced, have the threads roll formed instead of cut. No metal removal that way and they will be a lot stronger. Finding a shop to do it might be a bit harder, but not impossible at all.
Originally Posted by bomelia
OK, this is serious...
I need a steel shaft, 3/4" diameter, 30-36" long. Each end needs to be turned down and tapped for a 1/2" nut. Tapping length on each end should be 2". Balance is important.
I have looked around on the net, but not found what I want yet. mcmaster is too limited in their selection here.
Anybody here can help with suggestions?
Mike
