Hi, Gary.
What RPM do you run @ max, and did you take it to the dyno? Peak Hp@?
Your set-up sounds similar to what I run, although the volume of the new engine will be larger.
Does anyone have any suggestion to what changes should be done to the IDF's jetting if the main venturis are changed to 41mm? Jac MAc?
After looking throgh the posts on this theme, I have found rather inconsistent information- for instance some goes with 140 mains and other 190 or something. I know there are no simple recipee on this matter, but more input would be nice.
