Old 06-16-2008, 09:47 PM
betzjr66 betzjr66 is offline
Cobra Make, Engine: Cobray, 468 chevy oval port heads 10.5 to 1 Richmond 5 speed
Default trans
The trans that I got is the 4+1. I believe that it is rated at 450 lbs. I only plan on using street tires on this car and driving it for fun and to local shows. There is a possibility that I take this car to the local drag strip, if so, I would probably run a drag radial instead of a full slick and keep my fingers crossed. I believe that the wheels will break loose before the trans. breaks. the car will weigh under 2500 lbs. with the big block when it is completed. I am thinking of a 10 in. wide rim on the back with a 285/40 tire.
