I had this problem
I had a clanking sound coming from the driver's side rear on minor bumps too. I took the car to my tech. He tightened every bolt on the front and rear suspension. There were no bolts that were really all that lose - but all could use a little extra tightening. He explained that even though the bolt is tight when the car is on a lift - when you put the weight of the chassis on those connections, some movement may occur - so he really put some muscle on those bolts. All is fine now - no more noise.
Mark
