Revisiting this thread:
Found that if you use the LAK-15202 bellhousing you don't need to use the spacer. It is deeper than the LAK-15200.
On the concentric throwout bearing: I see PatrickT is not using one. What is the reason for using it? This is an additional $400 and I'm trying to keep the cost down. Does the standard throwout bearing work fine? Any issues?
DD
Dangerous Doug
"You're kidding, right?"
