Old 10-01-2001, 01:02 AM
Leroy Leroy is offline
Default fender clearance
You might check the frame to ground clearance and then check the body to ground clearance. I found out years ago with my cobra the inter panel that mounts the body to frame where off. I just raised and shimed the body up on one side to get it even.
Good luck.
Lee
FORD NUT
