Dangerous Doug Doug I have tryed the Hydro thrown out bearing from Tilton. It was a pain in the A$$. I wasted 1 clutch that got full of
oil on the disc and pressure plate. Once
oil gets on these things you can clean them till the cows come home. The
oil still seeps out of the disc. I tryed going out of the sand box from ERA. It was a $300.00 dumba$$ move. I have the orginial system back in the car and it is working fine. Tilton had problem with the thrown out bearing leaken, extending to far if you didn't have a stop for the clutch pedal. You follow what Doug says, and you will have no problems.
They have redesigned the Tilton bearing. I may try it again 1 day.
ERA tested these things before telling people that things work or don't work in there cars. They are there for you from start to finish.
Rick Lake
