Old 10-01-2001, 05:19 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Default IT DEPENDS, good2go,
on the material the camshaft itself is made of.
Most of the roller cams are steel, so a steel or aluminum-bronze distributor gear must be used.
A "normal" cam, usually cast iron, uses a cast iron distributor gear.
If you use the wrong mixture of gear/cam materials you will get the result you experienced. For example, a cast iron distributor gear used with a steel cam spells disaster.
My 514 crate motor came with a steel roller cam and a steel gear on the end of the distributor.
Hope this helps.
Tom
