Originally Posted by RICK LAKE
Rick,
Yes, the ETC system is an option on the FAST XFI system. Check out the following link for details:
http://www.fuelairspark.com/WhatsNew...t.asp?offset=5
The most difficult part of this setup involves fab'ing the driveshaft sensor setup. I started with a "standard" driveshaft sensor kit, removed the magnets and had a custom aluminum colar made to fit the flange on the ERA IRS center section. We then just installed the magnets from the original senstor kit in the custom part. Worked out quite well.
The injectors on the 482 are in the 50 lbs/hr range. The supercharged motor uses 60 lb/hr injectors.
- Fred
