Old 06-22-2008, 06:36 PM
BeasleyRB's Avatar
BeasleyRB BeasleyRB is offline
Cobra Make, Engine: B & B , 351W 400+
Default Hydraulic Clutch pedal set up
If you have the stock B&B clutch and brake pedal set up the clutch pedal has a hole in it that is designed for a brass bushing. B&B already had this options prepared for. The hydraulic master cylinder clevis goes through this perfectly. I used the Wilwood master cylinder and wilwood slave. I haven't had any problems with it at all. I think I have some pictures of this on my gallery if not I will put some up. Bob Beasley
