Old 06-23-2008, 11:04 AM
Double Venom's Avatar
Double Venom Double Venom is offline
abram,
on the front page opf the main forum there is a "sticky" post about a windows rezizer that Ron gives a link for. Neat little program which allows you to very simply down size your pictures. Thge one little trick I found was that you have to use some type of windows program to use to actually get the program to work.
On the brake leak, my "guess" is you are simply using the wrong size/kind of washers? if you are using the washers that came with the hoses then you may indeed have a bad hose. ???
DV
