Old 06-24-2008, 05:55 AM
patrickt patrickt is offline
Originally Posted by Kramer View Post
oil temp?
oil pressure?
water temp?
amps?
Here are "typical" reading zones for a SO (in my experience):
Oil Temp -- 85-100 C
Water Temp -- 85-100 C
Oil Pressure -- 18 to 20 lbs. at idle hot, rising quickly with RPM, 50 or higher, max.
Amps -- After initial startup you will see the needle more towards the + for a short while it charges back up. At normal cruise the needle will be straight up or slightly to the + side.
NOTE -- There is a lot of debate on the correct oil pressure for an FE. It all depends on the clearances and your pump. But for the most part, at idle you don't need nearly as much pressure as you might think. Also remember that if you have a stroked FE, you have a different crank in there.
