just cut the tubing round the wiries
found out yelow/green is fuel level sensor signal
black is ground for fuel level sender
other 2 should be fuel pump power
havent u got the other end of the wires which are cut opposite to fuel pump
where is gasket the plug on fuelpump assembly should come off pretty esily
or sorry its a ford pump so might take some hard work hehehehehehe
i just use factory holden fuel pump assemblies cheaper and i can get the factory plugs for them brand new
