Old 06-24-2008, 12:02 PM
jagrolet jagrolet is offline
Cobra Make, Engine: CR 347 ford
Default brake hose
If you are using the oriental braided lines the copper washers are really hard,go an auto parts store and get replacement washers.Also,make shure the surface is clean(no paint),and use 1 washer on each side of block.I have found some of these hose kits with the blocks milled with faces far from parallel.
Jagrolet
