Don't compromise the integrity of the frame. The engine WILL move somewhat when it under power and as you shift gears. Allow some clearance between the Bellhousing and the frame. Removing metal from the backing plate (between block and Bellhousing) outside of the Bellhousing is a better idea.
Rick
