Old 06-25-2008, 06:49 PM
raclaims raclaims is offline
Cobra Make, Engine: SPF-2659/Roush 427SR
Default Process is finally over! I'm NJ legal!
Well it took a while and was no easy process but I'm finally done and legal.
Ztarum did an excellent and spot on review of the process in a prior thread:
NJ title registration and inspection answers
So there is no need for me to reiterate it here.
I unfortunately failed my first title inspection. Man was that upsetting. I had to trailer the car to and from the inspection station...then trailer it back to the shop in Long Island to fix it up to their requirments. Then get it inspected again!
I have the list that DMV uses to check your car at the title inspection...they actually went over every single item on the list. If anyone needs it PM me and I'll email it to you.
I failed for the following items:
1. I did not have a vin plate on the car. I thought that DMV gives you a VIN but that is not the case. You can use whatever numbering you like apparently. I went with my chassis number from superformance. You must have a vin plate made up and "publicly visible" (meaning it must be open and obvious from outside the car and be either on the cowl, dash or center console by the shifter. Plus it has to be permanently mounted (ie rivets). This was the first item they looked for and said I would have failed just for this. I have spoken to others in NJ that didn't have this on their car and they passed but it was a huge issue with my inspector. I had one made up at a trophy shop and riveted it right behind the shifter and it actually looks pretty good.
2. There needs to be “two sources of acceleration return”…I had only one spring but they require two.
3. My fuel and electrical lines were run together under the car (he showed it to me on the rear of the car by the fuel filter). He called it a ticking time bomb and said it was a very serious problem. So I had to have them re-run separately.
4. You have to have four way flashers (hazard lights) hooked up and working. I had the switch but it was not working
5. My low level indicator/warning on the master cylinder was set to an audible warning sound but they require a light on the dash. I then had it hooked up to the red light on the dash to comply.
6. My front suspension springs were not locked down tightly enough…they were totally free and moved all over the place which he said was unsafe. He said this is a common issue with superformance and he fails cars for it all the time.
7. The battery needs to be vented. He said a hole needed to be drilled with a tube running out under the car and it must be grommeted.
8. I had one electrical line that was not terminated at the rear of the car by the fuel filter...I had to have that cut off.
9. My fuel filter was not mounted tightly enough to the frame for his liking so it needed to be mounted before and after more tightly.
10. The passenger front turning lamp had the bulb reversed and it needed to be switched (it starts as high beam so when the headlights are on and you signal a right turn you can’t tell it’s blinking).
So I had all these items fixed which was a huge pain in the rear end.
The inspector was very helpful and professional...just doing his job...but I was very disappointed after 7 months of putting this car together.
The second inspection he checked all the failed items and I passed. I went to Trenton the next day and got my title and plates.
Then today I had the normal DMV inspection at a private facility and passed...so for the next 2 years I'm in business!
But now my clutch is squeaking so looks like one more thing to fix!
My advice...make sure you check off every single thing on the DMV list...I really thought it would not be nearly as detailed an inspection as it was. I guess in the long run the car is safer. I can say that now that it's behind me....a few weeks ago I was not so happy!!
If anyone has questions just ask!
I have been driving the car non stop! Traffic isn't a lot of fun but all other times it's the best time I've had in a car! If you are in the middle of the grief of the build, etc...it's well worth it in the end when it's all done!
It's impossible to take the grin off my face!!
SPF-2659
