Originally Posted by Archrms
Bart,
I have BFG's on 15" rims on mine, and have zero vibration. I think you can narrow your problem down to tires, balancing or alignment. If the balancing and alignment check out, that only leaves the tires.
This is assuming that there is not a problem with your steering column etc., but too many SPF's do not have this issue for it to be design related, otherwise all of them would have it.
Good luck tracking it down.
I think your point is right on. It isn't a necessary evil since most or many do not have the problem. I do not understand how a aligment problem could cause a steering wheel vibration ?? I am about out of the cheap solutions. I will take it to a different tire dealer and go thru the process again...
