Originally Posted by Lowell W
Len,
There's a SCOF tech tip on this topic. If you haven't joined SCOF already, check it out.
Lowell
X2 on that suggestion.
Originally Posted by blykins
I can't remember how an IRS is setup....does it use the rearend housing cover as a mounting point?
If not, you could install an aftermarket cover/girdle. They all have drain plugs in them.
The answer to the first question is Yes. I added this nice brace from Steeda, as the cover can be cracked if subjected to
lots of torque. I didn't want to take any chances.
-Dean #747
