  #25 (permalink)
Old 06-26-2008, 07:25 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
I had 17" 275/45 Goodyear's FI Supercar tires on the front of mine. I bent one of the wheels, had it fixed and it was fine. When those wore out, I spent a $$$$ on a new set of Michelin Pilots. The original shop did the road force balance. I had a horrible vibration at the 60 to 75 mph range. Took them off and back to the shop. Another guy did it and checked the wheels tires etc. Still the same problem. So I took them off again and took them to a local performance shop that does a lot of work on cobras. They did the road force balance again, spun the tires on the wheels etc. Still had the front end vibration. So they had me bring the car in so they could balance the fronts tires on the car. Problem solved after a lot of work. It wasn't cheap to balance them on the car since it was at the regular shop rate, but it was worth it.
Now if I take the front tires off, I have to mark then to make sure I put them back in the same spot.
Scott
