My Unique Cobra is set up for a Ford FE engine. I am thinking about going with a 427 Windsor stroker. Does anyone know of an adapter bracket that will attach the Windsor block to the existing FE frame mounts. I may want to put a big block back in at some point in time. Have any of you guys (10%ers or other
) that switched from big to small used the existing motor mounts or did you cut & weld?? (I also don't want to mess up that power coating)
Also, did you have to change your transmission mount location or was that the base point for where the 351W is located in the frame? I don't have either of these motors laying around so I don't know the difference in shape or orientation/position.
Any advise would be greatly appreciated!
Thanks in advance
