Old 10-02-2001, 07:14 PM
dana dana is offline
Unhappy clutch or trans problem
I am having the engine, 392 crate and tko trans, installed now.
We started it up and set the timing. So far so good. He already bled the clutch, or so he thought. The pedal throw was real short, maybe 2" tops, and felt very mushy. It was not anything like the ones I drove before. Then we tried getting in gear, no can do. I did not force it. We turned it off and rotated the tires and got it to slip into gear. We checked the diffential oil, no problems there. We turned it on again, still no getting it into gear.
Suggestions?
Slave cylinder bad...
Clutch problem...
Trans problem...
Help, can barely control myself, soooo close now.
Dana
