Old 10-02-2001, 06:54 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Gravity bleed the clutch if you have the patience--also, is your t/o bearing hydraulic??They can make the bleeding process very aggravating. If you're SURE that you have all the air out of the system, I had a similar problem and it turned out to be a defective pressure plate (!!??!!) from Centerforce--I swapped it and PRESTO no more problem. I ran it down by watching the t/o bearing engage the presure plate while the car was on a lift--it moved it well, but there was no resistance and no shift! This has got to be a long shot--it's the only one I have ever seen in 20 years of shop work. Have you tried to reverse bleed the system--with vacuum @ the bleed port to suck fluid thru--we use a vacuula brand machine @ work, and it's awesome.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
