Old 07-01-2008, 08:56 PM
xlr8or's Avatar
xlr8or xlr8or is offline
Regardless of brand you will need/want to maximize airflow through the radiator.
Shrouding the front and shrouding a puller fan will help maximize it. You can lower the thermastat to a lower temp so it will open sooner. If you aren't running the bypass hose from the water pump to the intake, add that to see if increased flow helps.
