Old 07-02-2008, 02:08 PM
J Persons J Persons is offline
Cobra Make & Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
This is an Armandos GT40 pan. He will configure it any way you want, as far as oil temp bung and dip stick provision. If you are using a late model block, you will need a dip stick bung in the pan, or a front timing cover with the dip stick provision. You will also need to block off the factory dip stick hole in the block. They come fully baffled and with the correct pickup.
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
