Old 07-04-2008, 08:01 AM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I use a manual cable operated coolant control valve from NAPA, #6601141 spliced into the INLET side of the heater core. It has 5/8" hose inlet and outlet and is a straight-line model. I used a choke cable from NAPA and mounted it under the dash with the bracket included in the cable kit.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
