Old 07-04-2008, 11:48 PM
Mike C Mike C is offline
Cobra Make, Engine: FFR slghtly modified 302
My CC has helped a lot. Back problems kick in from holding the pedal on long trips. Used an Audiovox sys. from JC Whitney with some trepidation (cheap) but, it has worked flawlessly. Make sure to set the unit to the highest power to weight ratio & Keep the servo away from heat as best you can. I was able to hide the small control unit from the purists in a period correct British ashtray on the console. It connects to the brake light circuit & also has a rev sensor to disconnect when needed. Cheers, Mike
